Alloy-Driver, 12V
Dual 300mA 12V Driver
Germanium alloy transistors were an early type of transistor, faster than the earlier grown-junction transistors.
Part number:371881
PCB number:493181
Used in:IBM 1620
Symbol:D
Transistor type:071 083
IBM 1620 Instructional System Diagrams, p497.
Pinout:
A I1D B I1R C O1 D E O2 F G I2R H I2D J GND K L M -12V N P Q +12V R |
