SDTRL-Inverter, Power-PNP [SDTRL - Compensated Low Power Inverter]
SDTRL-compensated low power inverter
SDTRL -inverter, power- pnp
Quad Inverter w/ speedup capacitors
Saturated Drift Transistor Resistor Logic (SDTRL) is a form of resistor-transistor logic using faster drift-field transistors.
Part number:370646
PCB number:484425
Used in:IBM 1620,IBM 1311 Disk
Symbol:I, IP
I: Inverter. Changes a positive input to a negative output, or vice versa.
IP: Inverter, Power. Performs function of an inverter white also driving a line.
Transistor type:106
IBM 1311 ILD, p138.
IBM 1620 Instructional System Diagrams, p496.
Pinout:
A O4 B I3 C O3R D O2 E O3C F I4 G H J GND K I1 L O1C M -12V N +12VM P I2 Q R O1R |
