Control-Drivers,Brake and Clutch
Dual Open Collector Driver w/Pulldown Resistor
Part number:371779
Used in:IBM 1620
Symbol:D
Transistor type:028
IBM 1620 Instructional System Diagrams, p489.
Pinout:
A PD1 B PD2 C O1 D O1 E O2 F O2 G I1 H I2 J GND K L M -12V N +12VM P Q R |
