CTRL-Drivers,VM,Light or Relay
Dual Lamp/Relay Driver
Complemented Transistor Resistor Logic (CTRL) is IBM's term for a form of resistor-transistor logic.
Part number:371750
Used in:IBM 1620
Symbol:D
Transistor type:026 083
IBM 1620 Instructional System Diagrams, p487.
Pinout:
A I1D B O1L C O2L D I1 E I2 F O1C G I2D H O2C J GND K L +12V M -12V N -12VM? P Q R |
