Alloy-Driver,Current
Gated 270mA Current Switch w/Emitter Follower
Germanium alloy transistors were an early type of transistor, faster than the earlier grown-junction transistors.
Part number:371397
PCB number:492947
Used in:IBM 1620
Symbol:D
Transistor type:083 091/087
IBM 1620 Instructional System Diagrams, p483.
Pinout:
A II1 B I2 C IO1 D O2E E I1 F G H J GND K L M -12V N P -36V Q R |
