SDTRL-Standard Cable Driver
Simplex interface driver
Quad Line Driver
Saturated Drift Transistor Resistor Logic (SDTRL) is a form of resistor-transistor logic using faster drift-field transistors.
Part number:371987
PCB number:493259
Used in:IBM 1620,IBM 1414 I/O Synchronizer,IBM 1311 Disk,IBM 1410
Symbol:DL, D
DL: Driver, Line. Used to couple information between two widely separated points by means of coaxial line.
Transistor type:045/101
1410_SMS_VOL_1.pdf/1410_SMS_VOL_2.pdf, p2122.
1414 SMS Cards, p32.
IBM 1311 ILD, p111.
IBM 1620 Instructional System Diagrams, p481.
Pinout:
A O1 B I3 C I2 D I1 E O2 F I4 G O3 H O4 J GND K L GND M -12V N +12VM P Q R |
