SDTRL-Driver,Low Power-IO Base Non-inverting
SDTRL-driver,low,power-10 base non-inverting
Quad Buffer
Saturated Drift Transistor Resistor Logic (SDTRL) is a form of resistor-transistor logic using faster drift-field transistors.
Part number:370082
Used in:IBM 1620
Symbol:DP, DE
DP: Driver, Power. A power driver used to drive Into multiple bases.
DE: Driver Emitter Follower. A driver, operating on the emitter follower principle, used for power amplification, impedance matching, and isolation without inversion. Often used as a logical element.
Transistor type:045/101
IBM 1620 Instructional System Diagrams, p477.
