CTDL-Trigger
Trigger
Part number:371534
Field replacement part number:371534
Customer Eng reference number:729853
Used in:IBM 1401,IBM 7070,IBM 1410
Symbol:T
T: Trigger. A conditioned bi-stable device whose steady-state outputs change from one stable state to the other with two separate triggering levels, pulses, or voltage changes. The set input turns the trigger on if the reset input Is not on, and vice versa.
IBM Standard Modular System, Component Circuits, p60,61.
2_2 SMS Cards, p4,5.
1410_SMS_VOL_1.pdf/1410_SMS_VOL_2.pdf, p2089.
